Ali07
I have a 2007 ram 5.7 and I blew the rear end up, it had a 3.92 gear ratio and I put a new axle in it, but the ratio is 3.55, and now the transmission is being funny. When I put it in drive at a stop, it goes untill about 5 mph then it’s nothing. It’s like I’m in neutral. But when I put it in first, it goes just fine then I can shift into drive and it’s normal. Could that be because of the different gear ratio? Or is something wrong with my transmission? The axle under it now is only temporary. Untill I can save enough money to get better differential and the right gears because this one is a little bit worn. But what could it be? Once I’m up to speed it drives perfectly fine.
