Tim Denning
1986 D150 with A904 Automatic. Trasmission was slipping and leaky so I rebuilt it. After rebuild it worked great but the stamped steel pan was still leaking.
Dropped the pan and replaced with high capacity cast aluminum unit from Summit along with Lube-Locker transmission gasket. Still leaking around pan edge.
Inspection revealed that the lube-locker gasket sealing line was partially exposed on one side of the pan. Notified Summit and they sent another gasket out right away.
In the meantime, I decided to try 'The Right Stuff' gasket maker. Massive leaking all along the pan edge. Drain the fluid and drop the pan again. Sanded the pan lip using a granite slab with 220 grit. Sanding marks showed lots of warping on the pan edges. Sanded until a uniform sanding pattern appeared on the lip.
Noticed that the new gasket looked just like the gasket that was already installed. Checked gasket against original steel pan. Perfect fit. The new cast pan came with a cheap paper gasket so I installed it along with the expensive gasket in case that would help. No extra sealant applied and torqued per spec.
After install and test drive, dry as a bone.
5 days later, truck not moved...still dry as a bone.
2 days later, truck still not moved (but a storm did come thru)...Leaking around the edge of the pan! What the H*LL!
Does anyone know how a transmission pan can leak like that after sitting for many days without any changes?
Note: I'm pretty sure that there must be something up with the new transmission pan but I just wanted to check here in case there is something else I can do (Aluminum pans aren't cheap).
