Transmission problems
Steven edwards
Ferndale Washington
Hello I need some help bought my first truck and it is a 2007 2500 with a 6.7 so it has the 6 speed. The issue is I will drive like down the road or through town and every once in a while when I stop at like a stop light or a stop sign once I try to go again it will not go into gear it’s almost like it is in neutral I can sit there and rev it and it won’t move and then if I sit there for a little it will finally go into gear and drive normally. Today I was driving to work and I stopped at a stop sign and it did the neutral thing again and it threw the P0700 code and went into limp mode so I put it in reverse and got out of the way of everyone. After I say there for a while with it off I turned it back on and it worked just fine. Then after work I drive home like nothing happened. Idk what is wrong with it please HELP!
