Transmission Re-Learn
AustinB
AustinB
Banned
San Diego, Left Coast
I think the real question here may be getting overlooked. That may be my fault. I would like to know if calibrating the speedo alone, will fix the issue I'm having with it holding higher gears too long (feels like I'm in tow mode at 60+ mph). So in other words, does the speedo being off effect the shift points? Or is it load that effects it?
cableguy_hd
Danville, Va.
2020 Ram 2500 CTD
6.7 Cummings
It's probably taking more motor to move the 35" tires so I doubt a recalibration will stop you from hanging in the gear.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
The only thing correcting your speedometer will do is correct your speedometer. Only fix for what you are describing is more gear or stock height tires.
