Not really, as the coolant thermostat doesn't have much if any control over the trans temp. The trans cooler up by the radiator is air cooled not coolant cooled and the coolant is used for heating the trans fluid as much or more than for cooling it. The trans temp is controlled by a module on the trans that has it's own thermostat in the module. So if you are running a really cool temp thermostat, the thermostat in the trans module will just stay closed to get the trans fluid temp up. At least as far as I know.
I do know running a 190 stat in place of the 203 had no effect on trans temp on my 2016 hemi.
Pacofortacos is basically correct, but one point of clarification: at some point highly elevated transmission temperatures will be absorbed by the engine coolant.
From the 2019 Ram DT Service Manual
"This vehicle features an active transmission warm-up system with an oil-coolant heat exchanger on the transmission. The hoses are connected to the engine cooling system. The engine cooling circuit has both a three-way valve for coolant and a bypass valve in the transmission oil cooling circuit so the transmission oil can be warmed up more quickly from a cold start, which reduces parasitic loss from the drag of the spinning gears. If the transmission oil is getting too hot, such as during towing, the bypass valve setup directs oil from the heat exchanger and into the transmission cooler in the front-end cooling module."
Although in my experience the 8HP70 series rarely exceeds 200F in normal driving, and 210-215 under extreme limits, I would say that 245F is out of range for normal driving, especially when not towing over distance.
The question is will the 245F cause or be an indication of an internal transmission problem? The dealer is in a tough spot on this one because the factory will not reimburse under warranty unless something is visibly or functionally broken/inoperative, or there is a DTC set in the PCM.
There is a temperature sensor in the valvebody for measuring the transmission fluid temperature AND there is a setpoint in the PCM software to initiate a "Transmission Over Temperature" message. I am currently researching what the setpoint temperature is, but in the meantime it appears that it is not 245F , assuming everything in the system is operating correctly.
Best regards,
Dusty
2019 Ram DT 1500 Silver Billet Laramie, Quad Cab, 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, 18 inch wheels. Build date: 17 April 2018. Now at 023505 miles.
If we assume that nothing in the transmission is causing excessive heat generation, then I would suspect a faulty bypass valve.
It would be worth verifying the transmission fluid level, although there's a DTC for low fluid, also. But I'm not sure how low it has to be to trigger the message.
2019 Ram DT 1500 Silver Billet Laramie, Quad Cab, 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, 18 inch wheels. Build date: 17 April 2018. Now at 023609 miles.
I would also lean that direction too. I wonder if the bypass valve is not redirecting the fluid up to the trans cooler.
Hopefully he doesn't have a plugged or kinked line going from the trans to the cooler.
I haven't looked but does the 8 speed have a check valve on the line up to the cooler like the older transmissions did???
I sympathize with you because of the issues you have had. With that said, can you imagine a world where dealers had to perform endless free services and replacements based "on what people read" on the internet?? They ALL would quickly go out of business. In this case, would 199 be OK but 201 is not because you "read it somewhere"? No, the system can't work that way.
So what to do? The manufactures have to "draw a line" somewhere to indicate where a real problem exists and work is warranted. They do that by having a CEL light up when some parameter is beyond a predetermined set point. They are not trying to burn you. You already got the trans replaced once. That was not free for them by any stretch. If this one is working, then it works.
On the 1500's can you purchase an aftermarket bypass like is available for the 66RFE & 68RFE? This dropped my temps by 25-30 degrees. Something just isn't right with the OP's set up. I personally would do whatever I could to rectify this situation. Written statements from accredited transmission shops, go to another dealer, contact "Ram Cares" on this forum. Do any or all of what I mentioned. That is NOT normal temps!
Took truck to my tranny guy and he hooked up his diagnostic machine, I drove the truck for 20 minutes, got it to 231 but his machine said 199. So he used the heat thermal camera on the tranny pan and lines and got a reading of 165 and 170. So trans fluid is not running hot but sensor may be faulty or there is an electrical issue going on. Just glad it's not really running as hot as the truck says it is. They still won't even look at it because no lights are on and they won't take my techs word on the issue. I will continue to drive it as they say it's safe until a light comes on. Fingers crossed that it never does.
BS
Go in with the report from the "tranny guy" and demand they replace the temp sensor in the tranny. Do not accept NO for an answer. The new transmission has a faulty sensor causing a high reading. I know I am not, and I am sure the service reps are not versed in exactly how the computer interprets that high of a temp reading, but I am sure that it has to be in a range in which the ECU starts to modify certain parameters. Does it start to delay shifts? Maintain torque converter lock mode longer, etc. in an attempt to manage fluid temperature?
Based on the information that has been stated here, there is at least one problem. That is the fact that the computer will change the tranny fluid flow to the cooler at to low a temperature for the "designed operation" of the ZF transmission, i.e. the bypass valve will open to soon, and at a minimum you will lose fuel efficiency. Worst the tranny could end up operating at too cold a temperature for the load on the truck during winter months.
Contact FCA as well and start a case........
The TCM for the 8 spd transmission is part of the valve body assembly(inside the transmission).I think they should replace the TCM which they only did an update for after the park assist recall and that's when the problem started.
I am having the same exact issue with the over heating transmission. Had the transmission replaced 7 months ago at 65K. Now that I am at 81K and did a 1000k mile round trip from North Ga to Orlando Fla. At 70mph my transmission was reading 240 degrees. If I went up to 85mph it would jump up too 275 degrees and then I got a warning that flashed saying "I cannot maintain this temp mush longer". I had Dodge dealer check it out in Orlando last Friday and Saturday. They found no issue. They saw that I had a new Tranny installed and they said that they took it for a 10 mile ride but could not reproduce the issue. Mind you that the speed limit there is 65mph, so they did not go over that. Which where I live in GA, the top speed is only 55mph. And my dealer will not budge unless there is a code. I have about 15000k left on my warranty. I am going to attempt to get them to look at it with all the info I just read from you guys. But probably they will not do anything. The Orlando dealer was nice but said that they really could not do anything unless a code was thrown. I maybe SOL on this.
