Transmission
SIhemi
Pennslvanvia
I was wondering if it's possibly to change the transmission from the 5 speed to the new 8 speed. I'm asking because I have a feeling my tranny is gonna crap out on my in the not so distant future. They way I drive was wondering if it's doable.
BlackRamHemi
Edmonton Alberta Canada
No easy swap due to the engine tune and trans tuning are tied together in the same PCM.
You would need to find a stand alone trans controller, capable of accepting ZF8 tuning parameters
Then have stock engine tune adjusted to read it as a manual. (to prevent trans programming error codes).
also need electronic shift knob, Electrical connections/harness, cooler lines, thermal management unit, new driveshaft...
The cost would be insane for parts/install/tuning
...better off buying a new 14' or 15'
SIhemi
SIhemi
Pennslvanvia
Damn I didn't think that much was involved. Was thinking that the pcm would just needs to be flashed. Guess I'll just build up my 5 speed when the time comes.
Havix00
Sacramento, CA
2012 Ram 1500 Laramie
After your stock rebuild, consider a deeper transmission pan from Moe's Performance, some Redline C+ ATF 3 transmission fluid for deeper protection and extended life of your disks/plates, possibly a SharaDon stage II valve body to make the shifting firmer (less friction-time, prevents thermal wear on the new plates), or even consider getting your transmission rebuilt to a custom standard by Mike at from L&M transmission. Several others have his trannies and could hook you up with contact information. Check out this thread about it.
SIhemi
SIhemi
Pennslvanvia
Yea was planning to use L&M. Was just asking about the 8 speed because they are monster trans.
stevenmicheal
