Trick to folding seat down
AngryRams
Phoenix
I lifted my rear seat quite a bit, do I need to partially raise the back and then fold it down?
Sent from my SM-N950U using Tapatalk
muddy12
Indiana
The back seats do not fold down without modification. There are a number of threads on here about the “rear seat mod” or “ folding seat mod”.
Basically it involves either raising the rear seat mounts a minimum of 5/8” with spacers, or trimming the “catch” on the seat backs.
AngryRams
AngryRams
Phoenix
I did raise... Probably closer to an inch.
S0CAL
US Marine Veteran
The Lonestar State
2021 Limited Longhorn CTD HO DRW 4x4
Cummins 6.7L HO
Right, @AngryRams, now lift the bottom to about 45 degrees and pull the top away. You should be good to go.
AngryRams
AngryRams
Phoenix
Not working... SMH I know I lifted the back seat more than enough... Then again, my measurements are always wrong [emoji23]
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
Check the DIY section. I forget how many washers I went with. There is also a mod you can do in combination with lifting the seat bottom. You cut the clips a bit on the seat back (I didn't want to do that, but some say it's still a solid hold).
AngryRams
AngryRams
Phoenix
I didn't really try all that hard truthfully... I'll check it out when I head to gym in awhile.
WilliamS
Tampa FL
Pick the seat bottom up about 1/2 way then pull the headrest forward. If you raised the seat over 3/4 inch it’ll work
AngryRams
AngryRams
Phoenix
Do I need to pull on it with force? And wiggling or should it just fold down with ease?
S0CAL
US Marine Veteran
The Lonestar State
Cummins 6.7L HO
You're lifting up the bottom and it eventually frees the top, should be effortless.
AngryRams
AngryRams
Phoenix
It's not. Time to ***** in the heat again. Ugh!!!
WilliamS
Tampa FL
When your folding up the seat bottom watch the head rest. You will see it rise and hit a point and start coming back down against the back wall. When you see the headrest is at it highest pull forward on the headrest. It should release from the wall with 0 effort. If you didn’t raise the seat bottom high enough it won’t release from the catch.
How exactly did you raise the seat to do the folding mod?
AngryRams
AngryRams
Phoenix
Shims and a few washers
AngryRams
AngryRams
Phoenix
I'm thinking so to. I'll have to run by hardware store tomorrow.
You did all the bolts front and rear. It takes 3/4 or more to get it to work. I think you might be a few washers short
muddy12
Indiana
There must be some variation from truck to truck.
I was able to get the seats in my 12 crew cab to fold down with only 5/8” thick spacers.
PaPa_Brewskey
Gilbert, Arizona
I don't know you, so please don't be offended, but this seems like an appropriate time for a "That's what she said" joke...
AngryRams
AngryRams
Phoenix
***** I hear that all the time .... SMH. I had to use a load of washers/spacers to make this work. Ill post pics shortly..
