Truck build
Thanks....dam salesmen got me...was told gears were 3:73
They are 3:21.....doesn't say anything about Limited slip tho???
On the build sheet/window sticker it would be under options and it's referred to as a: Anti-Spin Differential Rear Axle
Easy way with these 8 speed trucks to determine which factory gearing(and stock 33") is to drive at 73 mph on the free and check the rpms when the truck is in 8th gear. If the tach is about 2K you have the 3.92(Hemi & EcoD), if it's about 1800 you have 3.55(V-6 & EcoD), if it's about 1600 you have 3.21(Hemi & V-6).
slim chance
lancaster, pa
hemi 5.7 eTorque
both or our Ram's build sheets and window stickers did not match ... window stickers left out many details
I didn't even read the build sheet.....i would imagine that the rear would be limited slip right?
If it's not listed on the build sheet, then a good probability it doesn't.
