I never measured mine stock so i don't know if i had the lean or not.
Edited: thinking about it yes, i must have had a lean on the driver rear and possibly driver front because i'm correcting for it with my King Coillovers. I have 11 open threads on the driver side, and 10 open threads in the passenger side. Everytime i've adjusted them i've kept that difference. They came with that minor difference as well from Kings. Will make sense because fuel tank is on the driver side, so that's a lot of weight back there when the tank is full, and you put the driver in place.
Every full turn in the 2.5 CO's = 0.2" lift. That small correction in the front driver pushes the rear passenger down so the truck is fairly even front and rear. My Icon springs doesn't have any correction like the factory. From what i remember reading we have one factory spring that is shorter than the other in the back. I just threw the stockers in the garbage so quick i never measured them
But also from reading, Bilstein springs follow that factory approach. Icons do not, I think Eibachs do not and many other springs do not.
I know
@hodge-xj ended up with a little lean after he did his Bistein 1" rear coils and he corrected it with a trim spacer from a JK, Hodge ?
I have the 26 gallon fuel tank, Hodge has a Diesel 1500 so maybe their tanks weight more ? OP what fuel tank do you have ?
I think just adding a small trim will correct that lean but it's weird the OP has indicated his front is even while only the rear driver is lower on the driver side. typically when you have a lean issue in one corner the oposite corner will respond in the opposite way. in this case if the rear driver is lower, i'd expect the front passenger corner to be a little higher and you can add a trim spacer on the side that makes the most sense. adding a 1/2" spacer in the rear driver will correct the lean but will also push the front passenger a little low.
Another thing to try is simply use and adjustable sway bar link on the rear passenger for example and make that side shorter, or do the driver longer and see what happens. Jeep little tricks
