boatmanea
- Feb 23, 2019
- 8
- 4
- Location
- New Brunfels, TX
- 2017
- Diesel 6.7l
2017 Ram 3500 dually 6.7l diesel 35,000 miles
Out of the blue, my truck decides not to start. Pressed the ignition and got a 'diesel warmup' message (it was 60 degrees outside!) Then tried to start, making one engine "turnover" noise, then nothing. Tried to start a few more times - same thing. Then the screens flicker and I get "service 4wd system" message. Ended up using my wife's car for the morning.
Later that afternoon, I check both batteries and both are holding at 13V. I run diagnostics and all I get is a "P24C7 particulate matter sensor temperature circuit range/performance" code. Not sure what to make of that. I try to start the truck, and it starts right up, no problem, no error messages, no flicker. I'm able to stop/start the engine about 10 times in a row without issue. Drove it a few miles - no messages or problems. Park it, and stop/start another 5 times - no problems. WTF?!?
Any ideas? Moisture in the sensor? Loose wires? Gremlins?
Thanks in advance.
-Erik
Thanks in advance.
-Erik
