K Musgrave
Push clutch and start , truck is automatic , 2014 Dodge Ram 3500
If your truck has a clutch but identifies as an automatic, then I would say it has an identity issue...lol
A little more of a description on not starting, does it turn over? does it just crank and not fire? Is there a CEL?
If it's a no crank issue, a good guess would be the batteries given that it's a '14 making those almost 6 years old if they're original.
If it doesn't fire, when was the last time the both fuel filters were replaced?
A little more information would help.
Does it turn over?
Does it just click?
Does nothing happen?
How cold out is it?
How long has it sat?
2018 Ram 2500 6.4L Hemi Tradesman
It will not try to start , security light blinks , because I unhooked batteries hopping for a reset , radio is also locked, lights also say service electronic braking , service abs
If it was built with a clutch pedal and a shifter, A.K.A a stick, it's a manual regardless of what it thinks it is.If your truck has a clutch but identifies as an automatic, then I would say it has an identity issue...lol
