Yip I have 35" tires too and it works ok but not great. Looking forward to the Truetrack.I have the stock lsd from factory. With stock tires it was good. Now running 35s and it’s ok but leaves a lot to be desired and this truetrac should clear all that up for me. I know it takes a little for it to load up but these 35s really stress it out.
The new off-road edition comes with an e locker and it’s the same rear axle just different wheel hub as far as I know so should be a direct fit.Wonder if an elocker will be coming next? Lol I'll hate life if I buy the TT and a few months later Eaton releases a locker for the ZF diff.
I have 93k miles and more likely it's time to refresh the LSD. I had a Detroit Truetrac in my Jeep Wrangler front diff and it was great. Best of all works great with cheap diff fluid that doesnt have FM in it. Most diff fluids have FM and that will mess with the gears and not allowed the TT to function as it should. So get used to $6 a quart bottles of diff fluid lol.
I don't see an Eaton part# for the DT truck, i'd guess some sort of ZF propietary elocker ?The new off-road edition comes with an e locker and it’s the same rear axle just different wheel hub as far as I know so should be a direct fit.
I’ve yet to find it listed but if you go to the 5th gen pages you can find some info. I’m wondering if the dealer can order it. Would be interesting but I’m ok with a truetrac myself. An e locker would be nice but overkill for me. I’m actually somewhat curious how the factory brake limited slip will function with the truetrac. I wonder in the 4th gens if the e locker may pose some issues with the computerI don't see an Eaton part# for the DT truck, i'd guess some sort of ZF propietary elocker ?
In anycase here is also more info regarding the TT for the 4th gen RAM
https://www.differentials.com/truetrac-for-ram-1500-coming-soon/
That’s the whole point of this. No need to swap axles. I understand that the truetrac has been out for a while but this is a model specific to the ZF axle that requires no modifications whatsoever. The 2010 and prior model axle is a corporate 9.25 design. The zf Model is an “updated” versionThese have been out for quite a while. The 2010 and older trutrac works in 2011+ trucks, same ZF axle, you just have to switch the diver side axle to a passenger axle which is longer. Other than that it's drop in.
I just ordered two passenger side axles from Moser when I installed mine.
