Tuner and chip stacked
StaLL1oN
Arkansas
2003 1500 Quad cab SLT 4x4
This may be a dumb question but I'm going to ask anyway...
Can you stack a Programmer and a performance chip on top of each other?
For instance My 3815 stack with this..
https://www.gfchips.com/cart.aspx
justin13703
MD
Please don't buy that, all that is is a resistor that makes your intake air sensor always read a low temp. Making that sensor read colder than the air actually is = jacked up a/f ratios and less power. And on top of that you're paying 70 dollars for a resistor you can probably get at radio shack for less than a dollar.
"Chips" pretty much stopped being a legit thing back in the 80s
StaLL1oN
StaLL1oN
Arkansas
Figured but thought I'd ask
ST-8
Diablo/superchips or sct/superchips
Hemi8073
03 so your only option is to do diablo/superchips, sct doesn't tune 03's. You can order a power wire which basically does the same thing as those "chips". I have one but don't use it. Once you get the 91 tune In there with some 91 or 93, it's a really good tune. Esspecially when you get that cam in there. Gears are really gonna help that dog feel you have on launch and acceleration. And the headers and exhaust really help that tune out. Your still on stock intake and mostly stock exhaust so the tune is not really able to shine right now. These motor really like to breathe and run really good when leaned out a little bit.
StaLL1oN
StaLL1oN
Arkansas
Always the best advice brother!
