Tuner & new pcm
savage_46
Alaska
6.4 swapped
I'm getting ready to order a tuner & I already have a pcm on the way. When I get ready to install, I just plug in the new pcm & then hook up the tuner, correct? Do I need to have the Vin programmed afterwards?
I'm trying to plan this out if it can be done in the driveway or if I should be at the shop for this.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Just install your new PCM first. Then you can load the Diablo tuner. You dont have to program anything else into the truck unless you are adding custom tuning as well.
S
savage_46
Alaska
6.4 swapped
Thanks hemi, I'll getting my order in with you later today.
