UConnect 5.0 RA2 PROBLEM
AFMoulton
Nuevo Mexico
So just got an RA2 in the mail today, plugged it in and it just has the UConnect screen. It will not reset or anything. I removed neg battery cable and waited an hour. Plugged back in and same story. Also have the service engine soon light, but truck runs fine.
I have the VIN and S/N for the new radio.
Any ideas will be greatly appreciated!
R.L.K.
Bristol , Tn.
The Svc eng light is likely from disconnecting the battery , this will go away after you drive it a few times .
Your a 2016 , what year is the RA2 from ?
I assume you removed an RA1 nontouchscreen radio ?
Did you have the battery disconnected when you plugged in the new to you RA2 radio ?
Sent from my SM-G900V using Tapatalk
AFMoulton
AFMoulton
Nuevo Mexico
2013 RA2
I did remove an RA1
And I did disconnect the battery when I removed and installed RA2
