Uconnect Issue
Mystic1906
Not sure if anyone else is experiencing this but a couple of days ago out of nowhere my screen started rebooting itself every two to three minutes. Coincidentally and worst timing ever it started happening at about hour 7 of a 10 hour road trip. I stopped to get gas, shut off the truck, refueled, and noticed it as soon as I got back on the road. I was using Waze for navigation so it was super annoying for the remainder of the drive.
Once we reached our destination I tried researching it and found a couple of suggestions (disconnect the battery and reset, check for recent updates and roll them back if possible) but none of them worked, there was no recent update that I could find and the battery fix didn't stop it. Since it wasn't affecting anything else I was able to drive around for a couple of days and while trying to enjoy our family vacation.
Just yesterday I figured I'd try disconnecting the Bluetooth on my phone just so my calls wouldn't keep jumping from the phone to the Uconnect. What I noticed was that the Uconnect stopped restarting. Not once for the 20 minute drive did it restart. I can't explain why this is happening and I'm hoping someone can provide some guidance on how to fix it.
turkeybird56
Central Texas
Take your phone, unpair it from U Connect. Cycle truck on/off a few times. Wait a few, repair/synch phone back to BT, see if that helps?
Also, it helps to know if phone is Apple or Android. On Apple phones, helps once in a while to totally shut down to clear memory on phone.
Depending upon your trim level of truck and U Connect, your system may need to be flashed also. Like if U have the 8.4, or 12", and whether n or not U have 911/NAV and stuff or just straight plain jane U Con 4 radio.
Mystic1906
Mystic1906
I have a Samsung Galaxy S22. I unpaired the phone and synced it back a couple of times with no luck. I was able to pair my tablet to it and it's not doing the restarting thing with that, it's only with my phone. At first I thought it was my Android Auto but even with that disconnected and only using Bluetooth it was still doing it. I tried checking to make sure my phone hadn't updated. It's so confusing because it had been working just fine before I stopped to get gas that day.
I have the 8.4" screen in a 2019 Big Horn Classic trim. It doesn't have the Navigation which is why I use my phone with Android Auto so I can get Waze. i drive a lot to various construction sites daily so I'm using it frequently.
turkeybird56
Central Texas
My only thought is you may need an update/reflash on your OS on the U Connect. Depending upon your radio, U may be able to go to u-connect site and download update.
On MY 19, I can do no OTA and site still shows my radio up to date, tho I know it is not. I would have to go to dealer to get updated, so I am still operating with the original OS when built in April 2018.
Bellaone
My screen has been flickering,fuzzy,freezing, apple
Car play has stopped working, ever since they fixed the delamination problem it had.
turkeybird56
Central Texas
Take truck back and have them fix wat they screwed up.
stevenmicheal
