Uconnect Update
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I just checked, no new updates for 14 and below. Latest update is 15.26.1...if they do as they have in the past the next update will start with "16."
danmp
Québec city, Canada
Same here, no update for my 2013 radio. I guess we won't get a new update since the are working on newer radio.
FlynDutchman
FlynDutchman
Menifee, CA
I think the Custom Tronix Rax Jailbreak is aprox $400.00 , if I remember correctly it allows you to stream movies and such while driving , turn on backup and or cargo camera (at the 3rd break light ) while driving , has inputs for 5 cameras ie back up , cargo ,front view and turns signals too . The front view comes on @ low speed to facilitate parking with a vehicle in front of you and the turn signal cams are mounted in the side mirrors and are activated automatically when you put on your blinker , it serves as a blind spot camera all cameras are on the radio display .
The Custom Tronix also allows you to mirror your smart phone to the radio screen thus allowing you to use your phones apps via blutooth on the radios display .
I may be getting some features mixed up between the Custom Tronix Rax Jailbreak and the Lockpick Air ? , I'm sure someone will chime in and correct me if that's so .
I have everything for my RA4 8.4 Radio upgrade and I plan on doing a Jailbreak when I do . So if you do this PLEASE post your results here , I'd like to know the outcome.
Hope this helps !
As soon as I get one and I get it done, I'll post it up. Thanks for the info!!!
R.L.K.
Bristol , Tn.
No problem Sir and Good luck with your truck !
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
FYI, you probably want the LockPick Air v2. It has built in streaming ability for iPhone and Android. I have one that I bought new but sometimes they show up in the classifieds of this forum used at a good price.
FlynDutchman
FlynDutchman
Menifee, CA
LockPick Air supports AirPlay if you are on iOS8 or older, other wise you would have to add an AppleTV to the lockpick.
I am currently using a iPhone 6 so the AirPlay feature on the LockPick Air would probably be the best for me. Thanks for the info, I can't wait to get this done.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Why? Any ideas what will work with iOS 9?
Apple removed the mirrorcast functionality on iOS 9 to force people to use Apple Air play.
(Edit/correction: iOS 9 only supports certified AirPlay devices, ie by Apple. Thanks Adrianp89)
Sent from my LG G4 on Tapatalk.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I don't think the iPhone ever used mirror cast on the LockPick (Android did). I'll check with my wife's iPhone and see.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Apple TV hooked up to your LockPick.
That would definitely work, but I don't think it's necessary as iPhone mirroring is native. You can also stream video/audio using DLNA.
pssnyderpc
2014 3500 Tradesman 4wd
6.7 Diesel
Thanks for the Information!
Snake_Eyes
6.4l Hemi
I'm trying to install the 15.26.1 update on my '14 RA3, it is valid for my VIN. The unit won't recognize the SD card, it thinks there is no card to read even though my computer can read it. When I try and use a thumb drive via USB it tells me the file is invalid.
I have updated previously to 15.25.5 so I know it works...the only thing that has changed is I am running a custom tune now. Has anyone had this happen to them and what is the fix?
roastpuff
What format is the SD card in? Make sure it is FAT16 or FAT32, don't think the truck computer can read NTFS or exFAT.
Snake_Eyes
6.4l Hemi
Its not even reading the SD card, doesn't even acknowledge that one is inserted. I haven't tried another card yet, but my suspicion is that the reader is flat out not working but I don't know why.
