Uh oh!
SgtNuzza
Northern NJ
Ok I pulled out of my drive way this morning and engaged the 4 wheel... Except it didn't engage. The stick moves freely.. I wanna say it's the transfer case.. She still drives thank god but I can't take it out of 2 wheel or anything... Any ideas?
MoparCody
5.9 L V8
By pulling the stick I'm guessing it's a 2nd gen. If the transfer case went out you wouldn't be able to drive it. You most likely either have a vacuum leak or your actuator went out. If the actuator went out, instead of replacing it with the vacuum controlled crap look into posi-lock. It is a lot better and its not vacuum controlled so no more worrying
Sent from my LG-P769 using Tapatalk 2
MegaMouseGW
South Louisianna
SRT 10 Viper Motor and Tranny
Sounds like a linckage came loose. Did you look under your truck to see if that happened??
SgtNuzza
SgtNuzza
Northern NJ
Yea just looked I'm missing the linkage. Is there any easy fix or cheap parts?
WhiteExpress
Midland, TX
MISSING the linkage?!
Junkyard will be your friend here, or the dealer.
SgtNuzza
SgtNuzza
Northern NJ
Looked around my driveway and found it.. But I'm just wondering... Couldn't I just make a bracket and bolt it on instead of using those stupid rubber locks...
Wchnu
South Louisiana
The new rubber clips are a lot better then the old ones. $10 each at the dealer. 15 min fix. Had to do that with mine right after I got it.
MegaMouseGW
South Louisianna
Glad you found it so fast. What alerted me to the linkage was you said the shifter was free moving.
A fix to this if you can find some is to get some all thread and bend it to the shape of the linkage and then run some nuts onto it to hold it in place or take a piece of steel or aluminum bar and use that. But realize that the rubber clips are there to prevent damage if something hits the linkage from underneath and replacing them with something stronger might mean trouble down the road. Another fix is to look through summit or a 4wd shop and see if they have a cable replacement for the stock one.
stevenmicheal
