SitKneelBend
- Jan 8, 2015
- 9,022
- 4,697
- Location
- St. Louis
- 2014
- 3.6 Pentastar
My G2s don't do the light dance?Yes, the one wire controls both top and bottom lights.
I can't answer your question about the dropout- I didn't check that.
The wires connectors is this one. I've seen them at both Advance Auto and O'Reillys.
On mine, if you set the DRL to not drop out the top bar stays white when the turn signal is active and turns off completely if you enable dropout.Thanks for the video! Now I see the appeal.
2 or 3 questions:
- Does the DRL feed wire control both the top and bottom DRL strips or just one, ie top?
- Have you tried setting the DRL Dropout to 'Disabled' to see how they function?
- Do you have any additional info on that matching 2 pin (male) connector for the alpharex DRL harness?
If I can source them, others may prefer to do the same.
M² Mods.
