Ummm...
ramthis9501
Oklahoma
5.2 V8
Can someone tell me what this is? I'm guessing it's the magnet that sits inside the differential housing, but look closer... It's bent up.
The gears seem to look good though, no missing teeth or anything.
Thoughts?
MADDOG
Living in a Firepit
The back half of the crush sleeve between the pinion gear & shims?
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
It couldn't be the crush sleeve, it would have to be sliced up the side for it to come off the pinion........
Sent from my VS920 4G
MADDOG
Living in a Firepit
Yup...yer right. So I'm wonderin'...did he check to see if it's magnetized?
ramthis9501
ramthis9501
Oklahoma
5.2 V8
Wanna make sure it's not something of importance. And I pulled the cover to check and make sure the gears were in good shape before I bought it. Now I'm getting the old gasket off and making a new one out of RTV so it can be sealed properly again.
ramthis9501
ramthis9501
Oklahoma
5.2 V8
I did, it didn't stick to the sides, but there's a little patch of grease at the bottom and it did stick to that, and it acted magnetized.
Hotroder383
Washington Mo
318 or 5.2 which ever you want
By the looks of the case some one has been in there before. It could be a magnet that some one put in for some reason.
ramthis9501
ramthis9501
Oklahoma
5.2 V8
I don't think its a magnet because that patch of grease is the only thing it acted magnetized to, so I think that's the magnet. I'm still not sure what the piece is, but I figure its still ok since the gears are still rotating freely with no lockups or anything.
Okiespaniel
Work, Shop, Computer
magnum, 5.9
Well, I wouldn't put anything loose like that back in...what does everyone else think? I just hope it's not a clip or other part from your lsd.
The thought that is is a piece of the crush sleeve...not good! It looks about the right thickness. Perhaps it was a "first attempt" by the mfr and the piece was never found.
Does the pinion have any linear (in and out) or side to side movement? It isn't split on the other side where it's smashed in right?
ramthis9501
ramthis9501
Oklahoma
5.2 V8
No the piece is not split and it didn't seem to have any play in the gears, but I'll check again later just to make sure.
ramthis9501
ramthis9501
Oklahoma
5.2 V8
Checked it, it is solid... No play in any of the gears whatsoever. I took a picture of what I'm talking about that I think is the magnet...
It sits at the bottom and that's where the metal piece was. Like I said though, everything looks good and is still moving freely, so as far as I'm concerned, it's ok. I'm gonna go up to the service dept at a car dealership tomorrow and get one of their techs to look at it and see if they know what it is.
Okiespaniel
magnum, 5.9
Yup thats a magnet...the other piece is something it caught.
Don't throw it back :). Toss it out. Hopefully it's not an issue.
ramthis9501
ramthis9501
Oklahoma
5.2 V8
So you think I should just go ahead and seal it up?
Hotroder383
Washington Mo
I would, looks like someone may have "lost" something while inside it. If the rear is on a workbench and you drop a clip or something it will fall into an oil passage and be a bear to take out. It may be someone dropped it and didn't bother tryin to take it out and magnet caught it.
I'd seal it up and fill with good oil.
stevenmicheal
