Under Construction.......wiring
RonVez
Ontario;CANADA
Hope All are well
Looking for a wiring GURU
Mine,2017 SXT,3.6 Quad
Donor,2018 Laramie 6.7 Crew,donated the overhead console HomeLink,Rear Slider and full harness(dome,mics,upper speakers)
powers going to console thru my current main harness(map lights working as well the Home Link buttons are lite,mics work for Blue Tooth) but no wiring for the Home Link
from what i can see on my harness,i'm missing 4 wires compaired to the console harness
missing are the Y/G,G/Br,G/R,Br/W (
I'm looking for the proper pins/connectors and wires(gauge an colors)as well as the connection points
in order to get Compass and rear camera feed on VP2(upgrading to 8.4 once back to work)
currently VP2 and Camera in mirror
If it makes a diference I have upgraded to 7"EVIC,VP2 an added the Steering Audio Controls
all with the help of this site an its members,Thank you
I've tried a few links in older post for diagrams but end up "Page not Found"
Any an All help greatly Appreciated
Thank you,Ron
RonVez
RonVez
Ontario;CANADA
Update
Believe these missing wires are for the Head liner Speakers(Laramie harness)
Managed to get Compass/Homelink activated using the AlfaOBD
Car config change.....Lin and Misc-Electronic Overhead Module.....Value YES
Compass showing on both EVIC and VP2 Radio displays
Still working on Back up Camera Display from Mirror to Radio
tron67j
Maryland
Did you get the mirror resolved. Got help from M2MODS with making backup camera visible in both mirror and radio at same time.
RonVez
RonVez
Ontario;CANADA
Hey tron
No havent resolved nor heard from any on this subject
preferance is to remove from mirror an add to stereo,
Upgrading to the RA3 w/nav shortly aswell,hopefully by then hear something
Fingers crossed lol
tron67j
Maryland
You can PM him at mpgrimms2 and ask about it. For my application it was a harness with male and female ends of a plug that is visible in dash passenger side panel when you open door. Then three wires plug into radio plug. Not sure your application but if you did not want mirror view it might be a removal of a couple wires from the separate harness(?).
tron67j
Maryland
this is the view of my plug after opening side panel and disconnecting tree plug holding it in place I inserted harness in between these plugs and then ran 3 wires to the radio.
