Perfecto Martinez
Hello,
I recently purchased a 2018 RAM 1500....I am now a first time RAM 1500 owner. Very excited about using this truck with my family for camping trips and other excursions. In taking a look at the undercarriage, I definitely see some surface corrosion from when the truck was used for the first two years in Michigan (I am in Colorado). I just washed the under side of the vehicle to remove a lot of the caked on mess. My plan is to spray the frame with Rustoleum Rust Reformer. Please take a look at these pics after the wash down.
First, any major issues you guys see that I should be really concerned about? I was going to go to town with a 60 grit pad on my angle grinder, but that seems a little rough, you can see where I started that at the front of the vehicle. My thought now is to just go over it with a steel brush first and then hit it with the rustoleum. Is it OK to just hit the whole frame with this, including where the bolts and nuts are? Any other advice you guys can offer?
Thank you in advance.
Perfecto
Perfecto
