Underdrive pulley
1slowR/T956
Does anyone know which is the correct tool for pulley puller on a 2013 ram rt its for the underdrive pulley???
1slowR/T956
Bump need to install the pulley but need the right pulley puller for 2013 ram model
Hemifatboy
Redneck Rivera
6.4 hemi
Are you talking about removing the crank pully and installing an underdrive pully ?
Dubstep Shep
Houston
2014 R/T
Just go rent a pulley puller from AutoZone or Orielly's.
1slowR/T956
A pic would help or part number so i can have an idea
Hemifatboy
Redneck Rivera
6.4 hemi
If you google , pulling harmonic balencer pully from hemi you'll get all kinds of pullers and pics
H8Speed
The one for other chrylsers Autozone gave me was a pain to get in the 3 holes and actually ended up chipping balancer.Ended up using a old 3 bolt style and putting washers and nuts on back side of pulley(kind of hard with my big hands),pulley popped right off.
H8Speed
Here's a picture to help out.
H8Speed
And a installed picture..Truck seems to rev faster after pulley and pick up some mid to top end.Now if it's worth the $400 price tag..that's debatable.
Paluby
Alaska
What size belt do we need when using the underdrive pulley from Moe's?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
09-12 trucks use a 77" 6 rib and the 13-up use a 71.5" 6 rib.
Rlaf75
East Hartford CT
2021 Bighorn
How does it affect the charging system? I understand these spin everything at a different speed. I had underdrive pulleys on an old car I had. At a traffic light the cars lights would noticeably dim at an idle and brighten up when the rpms are up.
Paluby
Alaska
With a tuner you could raise idle rpms yeah?
Dubstep Shep
Houston
2014 R/T
Not at all.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
I have been running one on my 2011 crew cab for almost 2 years now with no issues. As long as you don't have off road lights all over the truck and a 5000w stereo, you will be fine.
stevenmicheal
