Dustin Moldthan
- Mar 30, 2021
- 3
- 1
- Location
- Florida
- 2005
- 4.7 Magnum Engine Gas
I have a 2005 dodge ram 1500 slt quad cab 4.7 Engine non-flex
For the past 2 months, I have been having a p0300 misfire code (random intermitted misfire) and sometimes it will throw in a p0307 (cylinder 7 misfire) code. I have replaced my spark plugs in all my cylinders and replaced the ignition coil for cylinder #7 and still getting codes. My truck seems to misfires only when she is on a cold start. I can drive to Autozone and wipe the code and drive for hours with no codes pop up. Also when I wipe the code, I won't get the check engine light for about 4 days Back when I first bought this truck, I had the valve cover gasket replaced.
My coolant seems to be disappearing with no visible leaks anywhere. My truck had no heat so I replaced the thermostat and flushed the coolant system. I also replaced the water pump. The previous owner did put stop leak in the coolant system before I bought it. I have seen white smoke come out of the exhaust once but that was on a cold morning. (45 degrees or so). I also used to hear a bubbling noise when I accelerated but I haven't noticed it recently.
Now, this may be or may not be related but I wanted to put this in here as well. My cruise control will turn on and I can see it is on via the dash but it will not set.
This is possible stuff I think it could be but I could be wrong and wanted your insight on it. Intake manifold leak (or a vacuum leak in general) and a blown head gasket. If you guys have any other ideas or know how I can test to see what it is, I would really appreciate it.
