- Joined
- Mar 24, 2013
- Posts
- 1,095
- Reaction score
- 2,416
- Ram Year
- 2018
- Engine
- 5.7 Hemi
So I have this ongoing vibration that I'm unable to find on my own, HALP! Sometimes it starts around 55, sometimes higher, sometimes nothing all the way to 80. I've not been able to pin down a point at which it starts or any certain bump/turn that starts it either.
The vibe is general, you feel it in the seat, console etc. It does not shake the wheel. I'm 100% sure it's not the tires, it existed before and after getting new tires and also after I added balance beads to all 4 tires. Shifting to lower gears does nothing. Accel, coast, or decel does not affect it. I've shifted into low range and ran through the gears (maybe 40mph) and did not feel any vibes so it seems not to be transmission. Front driveshaft has been removed with no effect. Rear driveshaft ujoints are all smooth with no slack. Sometimes it's pretty light, others it's bad enough that I can just watch in my mirror to see the bed shake slightly in relation to the cab.
I've driven enough junk vehicles to know what various terrible suspension components feel/sound like, that is not the case here. I replaced the lower links on the rear axle as two of those bushing were slightly suspect; no effect.
The truck is a slightly odd bird being a 149" WB 1500. Hoping someone has fought this before and has a silver bullet for it.
