amurp14
I recently bought a truck and took it to an alignment shop because the steering wheel was pulling to the right. The mechanic called me today and told me that when he did his initial checks, the alignment was good which he thought was strange because he could see while driving it that the steering wheel was off center. So he rotated the tires, rechecked the alignment, and found an issue which he corrected by setting the front toe. He claims the steering wheel is straight and it drives much better, but I have not been to the shop to drive it myself yet.
I bought the truck with aftermarket XD wheels and Toyo A/T Open Country tires (don't recall the tire size off hand, but they are larger than factory)
My initial thought is that the tire circumferences are not matching left to right (because front to rear stagger has no effect on alignment), I have a bad wheel bearing/bent wheel, or the mechanic I went to isn't someone I should be returning to in the future (or a combination of these issues). I am wondering if there are any mechanics on here that have seen this type of issue before/can point me in the right direction of properly fixing this.
