Black06ram
This happens once in a while, but its happened enough over the past two years that I would love to fix it. Truck is a daily drier 2005 dodge ram 1500 quad cab 2wheel drive 5.7L hemi with only 56,000 miles on it.
every few weeks it will take an extra 5 seconds of cranking to fire the engine. this has happened when the engine is cold and hasn't been used for days, yet also will happen minutes after I have turned off the engine after a lengthy drive. happens in all sorts of weather/temperature conditions also. when I say intermittent and random, that is the truth.
I am certainly mechanically inclined, so this has been confusing. its not a charging problem, its not anything that generates a trouble code either. this just happens maybe 1 time out of 30 times; the engine takes a while to kick over. typically the engine fires in 1-2 seconds, but when it has to crank for 5-7 seconds that gets annoying and odd. Have done research on here, on other dodge forums, etc. I can check the fuel pressure bleed-off with a fuel pressure gauge, but i really don't think that if it was fuel pressure related it would happen so infrequently. cam/crank sensor slightly off? wouldn't that cause general improper running, not just intermittent long crank?
thoughts ideas?
thanks!
thoughts ideas?
thanks!
