Upgrade sway bar
Elkman
Monterey
V6
If there is too much sway then the factory springs are not strong enough to support a non-static load. I had sway problems with my 2500 and I added a double leaf set of SuperSprings for $445 and an hour of my time and the problem was fixed. Far less sway and far less wear and tear on the shock aborbers / dampeners.
I added a BigWig bar to the rear axle and it did help in one area, much less wheel hop in turns with the bed empty. That is really a negative attribute of anti-sway bars on sports cars but a big positive with a pickup truck with a solid axle and lack of weight in the rear.
KentG
SE Michigan
2020 DT Big Horn
HEMI 5.7 V8
Sorry to bump up an old thread, but I had a question about using the core 4x4 end links, what size bolt do you use with them to attach the sway bar to the end link? I assume you reuse the bolt from the frame to the end link, but does the core come with new bolts to the bar or do you reuse the old bolts from the Mopar part?
crazykid1994
If you order the set New with hardware it comes With everything you need.
KentG
SE Michigan
2020 DT Big Horn
HEMI 5.7 V8
Sweet, time to make an order!
Firebird
2019 Ram 2500
I have a 39ft 8000lb travel trailer. On the way home from dealer I had some sway. Im going to double check my e4 equalizer hitch to make sure its set up properly but should I upgrade my sway bar on my truck as well?
Are you towing with a half ton truck?
