Nice looking truck, how many miles on her?
Thanks. It has 134000. A little on the high side but seems to be well taken care of. Miles don’t worry me like they used too. Paid 18 grand for it
Going from a 4.7 to the 6.4 should be a real treat!
Enjoy
Actually the 2011 I traded in had the 5.7 so it’s a noticeable difference but not dramatic. The power wasn’t an issue just wanted a beefier truck for pulling my travel trailer.
I am sorry I was looking at your member profile & didn't notice that was a 2003 truck. Yeah with the extra weight of the 2500 you more than likely wouldn't notice much difference at all except for the ride. Actually the coils on the 2500 are not too bad. If you do like most on here, lower the air in the tires to around 40-50psi when not loaded, & the ride is just about as comfortable as a 1500.
I was just thinking about the air pressure on the way to work this morning. Do you run the recommended pressure in the front and just air the rear down? I would assume so because of the weight up front.
Good luck, I would never buy a HD truck with over 100k. My guess is, it was road hard and put away wet more than once. Transmission is probably nearing failure and I would bet you have wear metal in your oil. Do a oil analysis ASAP....
Well damn I guess I will just take this truck straight to the junk yard then. Thanks for the warm and fuzzy thoughts. I’ll keep it all in mind. Lol
I'm surprised you even made it off the lot then!
You can tell by the overall appearance how a truck has been driven. People who dont take care of them, simply don't take care of them. Meaning they never clean them, wash them, perform maintenance, or care about fixing any damage. Generally, if a truck has been abused, it looks abused.
