From your question, you definitely need to get the ford.RAM 2500 or F250? Which one do you prefer?
Show us a picture of the "RV". It matters. Alot.
Or atleast the specs of the RV.
Thanks for the input, folks. To clarify the setup: I’m looking to haul a Slide-in Camper with a dry weight of 1,500kg (approx 3,300 lbs), plus a front-mounted bike rack.Show us a picture of the "RV". It matters. Alot.
Is it time to just skip the 3/4 ton and go straight to a 3500/F-350 SRW? The cost difference in Ontario is minimal, but the peace of mind for a 1,500kg camper seems worth it.Or as said , up your options on towing , and just go 1 ton .
Thanks for the input, rzr6-4. To clarify the setup: I’m looking to haul a Slide-in Camper with a dry weight of 1,500kg (approx 3,300 lbs), plus a front-mounted bike rack.Not nearly enough info to say if a diesel is the right choice. As far as ram 2500 vs F250, this is a ram forum, so that overall answer there should be obvious.
Anyways....
1) do you already have a truck and this is an upgrade or are you starting from scratch?
2) do you already have a camper or are you looking to get one?
a) bumper/gooseneck/5th wheel?
b) pin and gross weights
3) how often do you plan to pull?
4) when not pulling, will this be a daily driver?
5) do you live in a flatter area or closer to mountains?
This is exactly why I'm torn. If I go with a Diesel 2500, the heavy engine eats up so much payload that a 3,300 lb camper (plus gear, water, and me) will almost certainly put me over the sticker GVWR.
Definitely 1 ton dually territory with that. It’s a no brained for me.Thanks for the input, folks. To clarify the setup: I’m looking to haul a Slide-in Camper with a dry weight of 1,500kg (approx 3,300 lbs), plus a front-mounted bike rack.
