Upgraded radio
officialtimmm
Houston texas
5.7 hemi 2500
When I upgrade my truck to the 8.4 radio will I need to flash it I have the codes and vin?? And also can I flash it using alfa obd
Ricks Ram
No, there is no special programming required or codes needed. All you will need is the 4 digit radio anti theft unlock code. You will also need a conversion harness if you want to do the full upgrade with the 8.4 bezel. Contact Mike @M2mods in the vendor section of the forum for anything you may need for the upgrade.
Sent from my SM-G981U1 using Tapatalk
O
officialtimmm
Houston texas
5.7 hemi 2500
I git everything I need just wanted to be sure
a17ram
