Upper Controil Arm Bolts wont allign!
Numan
Clifton, New Jersey
Ram 2500--Hemi 5.7
Having trouble installing the upper Control arm on my 03 Ram2500, Cannot get the bolt holes to allign and get the bolt in.
Do I have to jack up the truck to install them? I have been trying for the past 2 days just under the truck and on ramps.
Please help.. Do I need to jack it up anywhere on the axle or something else? I just don't get why the holes will not line up.
Thanks in Advance!
McBroom
Denison Tx
Hemi 6.4L
Thanks in Advance!
Are the UCA’s on the correct sides? Don’t feel bad it happens a lot here.
You may need to take it apart and start over. I’ve had to do this a few times before.
Can you post up some pics so we can see better to help you
Blue Streak Pearl off-road package
Numan
Numan
Clifton, New Jersey
Ram 2500--Hemi 5.7
Both Upper Control Arms are the same part number --I will post the pics of hoes not lining up when I get home from work.
Thanks you for your response.
