ram1500rsm
- Jul 24, 2018
- 4,816
- 5,282
- Location
- Trabuco Canyon, CA
- 2014
- Hemi 5.7
Yours shows better alignment numbers than that one I posted with the Billies at 2.1, caster at min, but should run just fine. Prob also why you guys with 4-6” lifts will have issues with aftermarket ucas and weird bj angles? There is some bracketry relocation in most of this lifts, so aftermarket ucas are not needed on those, although more than that, in some cases aftermarket ucas can create issues for you guys, think about it, the correction is perhaps built in the lift, so what the UCA is supposed to do will overshoot your geometry, when you lift the front, the factory UCA's are a little too short, so they can't move in the angle they need to give you correct caster/camber. aftermarket ones are offset to correct that.Here is my alignment sheet. Added my bils at 2.8 with my existing 6” lift, then had aligned.
