V6 Efan swap
djh1040
Southlake tx
Hey y’all, I was wondering if y’all think a v6 efan swap is worth it? I have heard you can achieve a little better mpg as well as hp is this true? Also is it just a plug and play or do I need a time?
Thanks
DILLIGAF
Canada
clint440
Graham WA
Free's up engine space. Improves initial throttle response due to less drag. Yeah you need a tune for it to activate it so it kicks on before 220. Otherwise, I believe you have to run AC to get it to turn on sooner. Did not notice any mpg improvement.
Have been using an E-fan setup for over 3 years and have towed heavy. No issue with cooling.
Jwithing
STL
Yes, it's worth it. I've been running the v6 efan with tune and without the clutch fan for at least 5 years. Removing the clutch fan frees up some parasitic drag on the engine as well
