V6 Electric Fan Wiring question?
nickpohlaandp
Lake Charles, LA
No, it was going to require way more work than I wanted to invest, so I returned it back to Dodge and im going to order the TYC fan just for the shroud and use my existing efan motor/blades and place it in the new shroud.
I don't think you'll be able to do that. You'll see when you get your TYC. If you can make it work more power to you. I found splicing two wires a hell of a lot easier.
http://www.ramforum.com/f44/clutch_fan_delete_writeup-89646/
Atincup
Frederick MD
Kotta390
Kotta390
nickpohlaandp
Lake Charles, LA
You are saying I can't remove the motor/blades to replace the TYC one? I don't care about the connector, I am more worried about longevity and no vibrations.
That's pretty much what I'm saying. I try not to use "can't", in my vocabulary, because where there's a will there's a way, but why go through the trouble when the V6 fan is literally a direct replacement minus splicing two wires? I would sooner splice two wires with crimp connectors than disassemble two fans and try to make one out of two.
Kotta390
Kotta390
True, I have just heard of people complaining about the longevity of the aftermarket Efans.
nickpohlaandp
Lake Charles, LA
It was $90. If it lasts two years I'm happy. These were OEM on the V6 trucks. I have faith that it'll last a lot longer than that.
Geo2slow4u
Madison,MS
My tyc fan lasted about 3 or 4 months. I know alot of other people have had better luck. So I spent $$$ and got a mopar fan. It definitely pulls alot more air.
Kotta390
Kotta390
Do you have a part number? A link to where you got yours?
nickpohlaandp
Lake Charles, LA
Just ordered a TYC fan. BTW what splices did you use on your wires? Do you happen to know what gauge wire it is?
I used yellow splices. I believe the wire is 8 or 10 gauge. The wires on the fan are one gauge down from the wires on the truck. After I did my crimp splices I used heat shrink to seal from the elements. Probably not necessary, but I had it so I used it.
Ramhead1911
Littleton Co
345 5.7 Hemi with mods
Hello All, I am going to do this swap, thank you all for the info. Can anyone post about results about how it is working a fews years later?
