Robertwc111
Does anyone have any links to where I can get a valve spring compressor for a 2004 ram 5.7? Can't find on anywhere
Trying to leave heads on regular tool is to tall for the back onesAre you trying to change the springs on the engine or removing the heads?
Thanks! Appreciate it might try thatUnfortunately this is the correct tool for the job
https://www.modernmusclextreme.com/p-52-hemi-valve-spring-tool.aspx
When I was in a pinch I took an old spring compressor and grinded down the jaws to fit inside the spring. It was rough but it worked in a pinch
