Naw a 3.21 still wouldn't get 18/19 mpgs, someone can correct me if I'm wrong but I'm pretty sure it would get worse mileage if anything. The bigger rear axle ratio will help spin those big tires making it easier to move the truck, thus better mpg. That's why some guys go to 4.10 or 4.56 gears with their lifted trucks.It has a 3:21 rear axle ratio which tells me why it was getting 18/19 mpg at 60 mph. Does that make sense or am I looking at it differently.
Thanks Egress for the info.
Plus 3.21 is pretty light for running 35's
Correct. The smaller number "3.21" means that you have less power with bigger tires "35s" meaning more fuel to make it move.
Dodge - Contact Us
select equipment listing from the left side, enter your vin# then go. I have found a few sites that will load a little more information, but this one does a fine job.
I was able to find the exact time and date my truck was built, I like little things like that.
I hit it and it sat down in the rear, but not as hard as I would of thought. But I was under the impression that the lower rear gears would give you a better mpg, not so good for towing but when I drove it this wk-end it had to me all the power I needed. I don't know you guys are the experts, please tell me, as I would like to possible put this in the drive way as it has about $6000 worth of stuff on it. Thanks for all of your help.
Sausage
That is really not a true statement. It would just take longer to get up to speed.
Overall running a 3.21 is going to provide higher mileage then a 4.10 because at a given speed the 4.10 is going to cause the engine to run at a higher RPM, therefore using more fuel.
