Could it be your connection to the remote? mine went bad and would only spool one direction. Cleaned the connections with a pipe cleaner and added electrical grease. works fine now.
I winched three jeeps out last week, ya three of em with one being my wife's jeep. My winch never completely stopped but lets talk about snails pace, geezus.
It was pulling a massive load, zoom in to the end of the cable and check out the snow depth on the back of the red Jeep, but holy crap did it take a hot minute, especially since we were beyond full cable and there's no clutch / free spool mechanism. My flippin Can Am has free-spool and I think its a Harbor Freight winch.
The unspooling was the most painful part Mine very well could have been a code-18 (18 inches from the controls sits the problem ) but I crawled around down there for a bit and I didn't immediately see free-spool, so I sat in my truck and held the button.
2016 RAM 2500 pw | 392ci w 6spd | CAI w ARH long tubes & Solo | Diablo T2 w HF tune | 5.13 AAM w 35" Mickey MTs | Custom Graphics w illegal tint | Dodge Off-Road
Found a very complete treatise on another forum on how to fix/bypass the thermal protection switch. Is it OK to post a link to another forum here?
From the Warn manual.
Winch Mechanics
Now that you’ve familiarized yourself with your Warn winch and its components, we can begin reviewing how it works. The major advantage of an electric-powered winch is that it can provide reliable service for intermittent utility and recreational use even while the vehicle’s engine is stalled — assuming, of course, that sufficient battery current is available. Your winch can operate at high current loads, and, for this reason, uses a high current switch system to safely handle the current flow.
It is important to understand that the longer the pull, the more heat that is created, just like a hot plate. Powering out the rope also generates heat and drains the electrical system. Whenever possible, unwind rope by “freespooling.” Prolonged winching without cooling the winch motor will damage the motor. Also, even if the engine is idling during winching, the battery may drain faster than it is charging. So pay close attention to make sure you aren’t draining your battery too low to start your vehicle.
Winch Mechanics
LOL. I never saw that either! Thanks for the pic. I’ve only used mine three times. Once to let out all the line and twice to get out of the mud. Every time I thought there had to be a free spool lever but never have the foresight to look when I’m not knee deep in mud.
Yes mine did this, I even made a thread about it here. warn is overpriced junk.I don’t mean to revive an old thread, but I recently had an issue with my 2020 PW winch that started “popping out” of spool during a line pull. Is this what you guys were experiencing here in this thread?
You can see it happen in this video I recently posted on my YouTube channel:
Overlanding from San Antonio to El Paso
Turned a routine road trip into an two-night overlanding adventure with just me and the kiddos!youtu.be
It happens at 20:11 and a couple times after that. It just seems to pop out of spool and go into feee spool. It was also much louder when free spooling the line out after it would do this.
