Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Just a heads up guys with cft links, the ball joints might dry up and stiffen so when you lower the truck they will brake the plastic leveling sensor...
take them off clean n grease the ball joints..
heres a pic... mine dried up and broke the sensor..
This could happen regardless of what links you have. Have to clean and lube regularly not to have issues especially depending on environment you regularly run in could shorten the length between maintenence on them.
