Warning light
Scott Glenn
Roxboro
Warning light passenger side brake light out ,but light is working
S
Scott Glenn
Roxboro
Warning light passenger side brake light out ,but light is working. How to fix false warning light on a 2023 ram 1500 warlock?
Curmudgeon
York, Pennsylvania
2014 1500 Laramie 4x4 QC, 3.21 rear, 8-speed
It always "shows" the passenger side, doesn't mean that particular lamp is out.
Also check the driver's side, and don't forget the 3rd brake light. This seems to be the most frequent.
loki223
Spokane, WA
Cummins 6.7
I would delete one of the duplicate posts so all the responses stay in one place.
I wouldn't change a thing and just be glad someone knows how to write an abbreviated search prompt even if this isn't a search engine
One Mile Up
Colorado
6.4L Hemi
^^ This ^^ It's almost always my 3rd brake light! :mad3:
Few weeks ago I decided to NOT be lazy and do the little "upgraded" seal on that fricke'n unit too... only took about 45mins to take it all apart and properly seal it up...
I decided to try out all L.E.D.'s -- got them all from (sing it with me, now!) O-O-O-O'Reilly's --> ...AUTO-PARTS!
They are most definitely brighter than the factory bulbs! :cool:
hunterdan
SE PA
2019 classic
Warlock has the led brake lights, so I wouldn't be surprised if there's a led or 2 out that's triggering the warning.
Rkimbrell
Weston Lakes TX
Cummins 6.7
I have had that warning twice on my 2015 2500. First time it was bulb in the back of cab over the bed.
Second time, nothing wrong, everything working. I Googled the issue and found that you can remove several fuses and put them back in to reset something(don't remember what...hell, I'm old). The warning went away.
Kayci
Alaska
6.7 diesel
sorry don't know how to delete this booboo.
Kayci
Alaska
6.7 diesel
My 2017 (6.7) told me that too. 7 yrs after I broke the plastic. The tape had come loose and had water in it. still worked fine. I happened by the dealer, he told me to check 3rd brake light over the back window. They are notorious for leaking ( into cab as well) but it was fine. I bought after market pair of lights for 89.00. worked fine after replacement. Warning left too.
