Water leaking into my door panels and speakers...
OrionR5
Toronto, Canada
2019 Ram 1500 Sport
Guys I posted a post under the Interior Sub section. You may or may not be in that thread to read it. This is in regards to water leaking into the door panels and speakers.
I had no visible signs of a water leak until I removed a door panel to do a speaker swap.
I would recommend you pop a panel or two to see whether this is happening to your truck. I would not have known had I not decided to upgrade my speakers.
troutspinner
Gilbertsville, Pa
2019 Big Horn Crew Cab
In general, water collecting in doors is normal for any vehicle. Make sure the drain hole is not clogged if it is remaining inside.
Rherman1
Sunny Florida
6.7 Cummings
I had water on my passenger side door speaker when I swapped it out also. Hmmm I might have to call the dealership tomorrow.
