Well yesterday was a bad day, I found a nice 8 inch by 8 inch wet spot on my driver side carpet. Upon further inspection I determined it was not coming from the fire wall. I checked the back seat flooring and passenger side front seat flooring, all dry. So I removed some trim pieces, weather stripping, and uplifted the driver side carpet, ABSOLUTELY SOAKED! I cleaned what I could with a towel, and used my wifes hair dryer for an hour to dry the carpet. I noticed a small hole in the welding from the cab to the fender, very tiny and easy to miss, this aroused my suspicions. I poured a large amount of water on my windshield and low and behold that small hole began to drip. Makes sense for the amount of water I found, I've had the truck since November 11th, and it rains in Virginia quite often so the small drips added up over time. I cleaned the area real well and applied some clear silicone into the small hole, I then used gorilla tape to cover the spot and add an additional seal (tacky I know). I reinstalled everything and the silicone and tape can't be seen (thank God). So far so good, I have an appointment with the dealer on Monday so I can atleast have this incident logged for future reference. If I were you guys & girls I would check your driver side carpeting for dampness. I'll include pictures of the hole for your reference. I'd also like to mention that I DO NOT have the sunroof (I heard those are leaking like crazy).
View attachment 191979 View attachment 191980View attachment 191981
