Water pump
jdeere05
Indiana
Hey guys 2010 ram 1500 with a hemi noticed the black metal line coming off the passenger side bottom of the water pump had some rust issues and was wanting to know can you replace that line or whole water pump?
whetrick1
That line is probably pressed into the pump. I don't really know that if you pull it out that you could get another one to seal in the pump. And if you mess the pump up when you buy a new one they might not give you full credit on the core charge. That's if it has a core charge on the new pump.
whetrick1
From the pic it looks like you might be able to replace it if you can find one.
powderbrad
Edmonton, AB
Yank in out!
Then use aviation gasket sealant on it and jam it in there.
I also don't know if this will work. Worth a try?
Likely can't buy just the tube though. Buy some cooper and flare it?
stevenmicheal
