Anyone try this? Seems plausible.
Id imagine a lubricant would smear the windshield, and be a pain to get off. When I clean my wiper blades I use alcohol wipes, cheap and gets the job done.
alcohol is what cleans the wiper blades
Did you ever get wd-40 on your glass? Its the most hardest thing to clean off glass. We as kids would spray it on guys windshields we didn't like. When it rains and you put wipers on you can not even see out the windshield. So I would never let wd-40 come in contact with my glassUse alcohol to clean and then use wd-40 it will soften the rubber as rubber tends to absorb it.
It streaks the glass when you turn them on when its raining . Hey you can do what you want but I for one know what it does and good luck trying to get it off the glass. I know some guys had to compound the glass with a machine.If you pull them off the glass and let them sit for a few hours then wipe with clean rag. The rubber will absorb it and should not affect the glass.
I,ll join you in cleaning the blades after the riotsI got some top notch tequila I might try lol
