Neon
Hi Gang
I've got a 2014 RAM 1500 with projection headlights.
Yesterday I got a dash warning of a "Passenger side indicator light out". (always thought the LED indicator lights were build into the headlight?)
I pulled the front tire off to release the headlight holder, removed the grill and undid the screw holding the headlight in.
Popped the headlight off and turned the headlights on to see what was happening and I have NO high beam OR low Beam on the passenger side?
Now I know they both can't burn out at once?? (drivers side are both working fine?)
Is there a fuse that controls the passenger side lights?
Do you get a "indicator" light warning when your headlights go out?
NEVER had any prior headlight issues ever.....?
Any help would be appreciated.
