warlock6969
Nitto the bestTomorrow I am going to get new tires, with road hazard. I am leaning towards Cooper Discoverer AT3 or Toyo Open Country AT3. Opinions?
I ended up going with Nitto Recon Grapplers, dealer putting them on in the morning, they had a sale and were considerably cheaper than the Tire Kingdom, as a plus they will reprogram my tire size (for a fee).Nitto the best
Sweet, I put Nitto on everything my Can-Am side-by-side’s even got a setI ended up going with Nitto Recon Grapplers, dealer putting them on in the morning, they had a sale and were considerably cheaper than the Tire Kingdom, as a plus they will reprogram my tire size (for a fee).
JeffersSweet, I put Nitto on everything my Can-Am side-by-side’s even got a set
Aye. I run Ridge Grapplers on my overlander and as soon as these Chinese BFG KO2 rip offs need replacing on my 2500 I'm getting another set of Ridge Grapplers.Nitto the best
iNitto the best
4421 is the Date code 44th week of 2021. If they are "Blems" or "Seconds" they should be so marked on sidewall - assuming they are not so marked, go to any local BFG dealer and get them to warranty the tires for Manufacturing Defect and replace them. Within 5 years of date of manufacture, you should have no trouble with a reputable local BFG dealer regardless of where purchased.The date code is 4421
I usually run them around 40psi (these are E load rated), but I noticed when I took it to the dealer they lowered it to 32/35
Yeah, I'm not sure if I am quite ready to join the cult yet, but we'll see how it works out.Sweet, I put Nitto on everything my Can-Am side-by-side’s even got a set
Yeah, it was New Smyrna CJR, it just went in last week for service and that tailgate thing. I've been meaning to air it up.Was that a Ram dealer and what pressure is on the door jamb? I thought most were 39 PSI.
I usually inform any place I drop my truck for an oil change or whatever, my tire pressures are set, do not adjust the pressure.
And more often than not, I verify they haven't changed them before I leave the parking lot.
I'm a bit crazy for tire pressures. I tweaked one tire this afternoon because it was 1 PSI higher than the others.
Proper tire pressures directly affects performance and longevity and I want both to be exceptional after paying top dollar for good tires.
I have a good quality analog gauge and I'm not afraid to use it. Plus, tire pressure can be checked on the EVIC.
Yep. Exactly why I did not buy CoopersSince GoodYear became interested socio-political activism, I became disinterested in giving them my money.
