Three Rivers
WOW! That's nuts!no. both in Lawrence county (Ellwood City). She needs (Neshannock) it and I don't. My son is in Beaver County (North Sewickley) and needs it
yep. There is an invisible fence going up to the atmosphere between Ellwood and Neshannock....lolWOW! That's nuts!
Your son and daughter should just register their vehicles at your address.yep. There is an invisible fence going up to the atmosphere between Ellwood and Neshannock....lol
Anyone in Allegheny county with a Power Wagon? I have a 2021 and apparently you have to have the emissions test done with a two step tailpipe inspection like they used to do in the 1800's!! Nobody in my area still has these machines and if they do they are broke and need obsolete parts. Long story short where is everyone getting their Power Wagons emissions tested in Allegheny county? Tha
Here is something to look into. In New York State when we registar a vehicle (used of course-as a dealer will tell Motor Vehicle what the max GVWR is) What we want for a GVWR. For instance my 2016 Ram, 5.7, A-6 (65RFE) has a payload of 1700 lbs. and a max GVRW of 6600Lbs ! That means the trucks weight is 4900 (6600-1700). The more we register for the more we pay annually for Insurance. Up here if the computer says there are no codes or malfunctions - our inspection machine get plugged into the diag.link- it can see 9just like any scanner codes and if the computer system says that all internal tests are in the "ready" state. They (NYS dumb-o-craps) that if the computer says it is OK then it passes its emissions. When I registered it I told them to make it 6000Lbs. I save on insurance. If I sold the truck the next person would automatically get that same number unless they (new owner) changes it. If DOT pulled me over and actually weighted the truck with what ever load I had in it and it was over the total of 6000 lbs. If it was bought new the dealer would have registered it for the full 6600! I would be issued a ticket, and have to unload somweight before I continued. Same with Class A's B's etc. However noone DOT inspects any no comerical vehicles up here ( not they couldn't they just don't). I just looked up "trailer tow and payload rateings for 2021 Ram 2500. Some have a GVRW of 9900lbs. some at 10000lbs. Which if in that truck past was "altered" you could fix that (?) At least in NY you could. Check to see what info your county accepts as valid info, for "real" GVWRAnyone in Allegheny county with a Power Wagon? I have a 2021 and apparently you have to have the emissions test done with a two step tailpipe inspection like they used to do in the 1800's!! Nobody in my area still has these machines and if they do they are broke and need obsolete parts. Long story short where is everyone getting their Power Wagons emissions tested in Allegheny county? Thanks!
