IJW84
- Feb 19, 2016
- 100
- 7
- 2008
- Hemi 5.7
What causes the power steering hose to leak from here, is it the hose that goes bad or the clamps or both? What’s a good fix? This is from a 17’ and exact same spot on my 08’. That’s just right under the radiator
Not this one. Maybe because it’s a 2500. The 08 is a 1500. But the leak is the same on both17's are electronic steering
I do that with all my OEM one-time clamped hoses. Just replace the hose every few years is cheaper than routing a replacement hose. Just one word of advise, especially with coolant lines that carry the engine oil: double clamp! Use two clamps next to each other.Take the clamp off, take hose off the metal connection. If the hose looks good, (if I have enough slack in the hose I usually cut off the part the old clamp was on) clean everything up good and put a regular hose clamp on it. Do NOT over tighten the screw. You want the clamp tight but not cutting into the hose.
