There are only two of them both on the drivers side. I hope they have more bolts then that holding the bed on(-;Covering the bolts that hold the bed to the frame?
Pop them up and see if there's anything under themThere are only two of them both on the drivers side. I hope they have more bolts then that holding the bed on(-;
Now I will hove to go out in the 13 degree weather and see. Well maybe I will wiait until it hits 15(-; Well I just went out and popped off the cover. I see the top of the frame, no hole or any indications of what is there for. Also no that is not rust it is dirt in the bed.Is that rust in the bed on a 2025?
I popped them off to see. The only thing I saw was the frame.Maybe something for access on top of gas tank where fuel pump or evap live on both 26 and 35gal tank options? (If those are still the right sizes in 2025)
That's not what those are for.....The four spacers fit the framework to mount the brackets for the trailer hitch of a 5th wheel hitch. The single bracket holds trailer ball for the Gooseneck hitch. All are supported by being attached and supported by the truck frame. Works great ..
Read post #1 and post #3 closer,he's only got 2 and both are on the drivers side of the bedLooking at pictures posted at the top of this post there 4 mounting bracket’s that are designed for the 5th wheel hitch. I’ve owned and installed the hitch’s numerous times. All were on 2500’s. The single bracket is for the goose neck hitch. The End…
