i think they look factory. They look like other blunted wires the factory uses. What for i have not a clue tho.That's not factory. Idk if you bought your truck new or used, but my guess is that either a previous owner or the dealership removed a system like a GPS tracker or alarm system from your truck. And that's most likely a common grounding point.
Those are the factory snow plow prep blunt cut wires.I was pulling wires for my auxiliary fuel tank pump and found these wires coming from under the power distribution panel. Does anyone know what this is for?
